daz Posted August 3, 2018 Posted August 3, 2018 What power supply can I use with duma cause mine just went pop in quite a spectacular fashion
Administrators Netduma Admin Posted August 4, 2018 Administrators Posted August 4, 2018 Hi Daz - which country are you in? It's quite easy to find a replacement if you call up a good electronics hardware store. Here's the spec: https://mikrotik.com/product/18POW The diameter of the pin is 2.0mm iirc. Let us know if you have any problems and we can assist further.
daz Posted August 4, 2018 Author Posted August 4, 2018 I'm in the UK , you know of a different brand that fits cause this is my 2ND one to go pop
Administrators Netduma Admin Posted August 4, 2018 Administrators Posted August 4, 2018 Just PM'd you
