Congestion control not working. Might need a firmware rebuild?
Moving sliders does not seem to work properly as my bandwidth goes over set  amount and varies.
Hi, welcome to the forum!
With Share Excess enabled this will be allowed to happen. If you have it enabled and set a device higher than another, it'l essentially prioritise that device unless bandwidth is urgently needed elsewhere. Speed tests will show that every device is able to take as much as it requires.
If you don't want this to be the case you should disable Share Excess and run more tests. Hopefully you should see the results you want :)
