Administrators Netduma Admin Posted July 21, 2018 Administrators Posted July 21, 2018 Had you just reduced the size of the filter? Do you have more than one device at the top? Could you take a screenshot of your entire page when this next happens instead of splitting the images up as it will make it easier to spot the issue. This is 99.9% likely to just be a settings issue so should be easy to fix.
