Nola504 Posted June 22, 2018 Posted June 22, 2018 i need help configureing my r1 with my pc and ps4 plz
JOE1305 Posted June 22, 2018 Posted June 22, 2018 i need help configureing my r1 with my pc and ps4 plz what exactly do you need bro? give some details.
Administrators Netduma Fraser Posted June 22, 2018 Administrators Posted June 22, 2018 Hey, welcome to the forum! I've moved this topic to General Support. As above please provide us with some more details and we can help you out.
Nola504 Posted June 22, 2018 Author Posted June 22, 2018 what exactly do you need bro? give some details. i need help setting up the router i just got it and my speeds are reallly slow i have the 1 gig down and 50 up internet package what info would u need fromm me?
Nola504 Posted June 22, 2018 Author Posted June 22, 2018 i need help setting up the router i just got it and my speeds are reallly slow i have the 1 gig down and 50 up internet package what info would u need fromm me? sure and thanks what info do you need? i have np giving u any details that u need
Administrators Netduma Fraser Posted June 22, 2018 Administrators Posted June 22, 2018 I'd first recommend going through the Introduction Tour that you can find here: http://192.168.2.1/cgi-bin/tour.shthat should get you setup. You won't get your full gig speeds via wired but more likely 600-800mbps. For speed don't put in 1000 put in 999 instead.
Nola504 Posted June 22, 2018 Author Posted June 22, 2018 I'd first recommend going through the Introduction Tour that you can find here: http://192.168.2.1/cgi-bin/tour.shthat should get you setup. You won't get your full gig speeds via wired but more likely 600-800mbps. For speed don't put in 1000 put in 999 instead. okay ive done that part i had 900 and 50 put in with reactive setting turbo and super turbo both enabled i have upnp off and i opned ports that are on ps4s network guide
Nola504 Posted June 22, 2018 Author Posted June 22, 2018 the cloud settings and the lan and wan page are what i need help with
Administrators Netduma Fraser Posted June 22, 2018 Administrators Posted June 22, 2018 the cloud settings and the lan and wan page are what i need help with You shouldn't need to touch any of those settings, all the important settings have been done already so you're good to go.
JOE1305 Posted June 22, 2018 Posted June 22, 2018 sure and thanks what info do you need? i have np giving u any details that u need here you can also find some guides that can help you out. http://support.netduma.com/support/home
Nola504 Posted June 22, 2018 Author Posted June 22, 2018 well im gettin slow speeds on pc and ps4 still they dont tell me specifics on those guides ive looked at them already
Administrators Netduma Fraser Posted June 22, 2018 Administrators Posted June 22, 2018 well im gettin slow speeds on pc and ps4 still they dont tell me specifics on those guides ive looked at them already How slow and are you using ethernet?
Nola504 Posted June 22, 2018 Author Posted June 22, 2018 20 mbps down and 2.1 up and yes i am i get 800 + down and 50+ up on my asus ac3100 router my could settings are all 1 it wont let me change them How slow and are you using ethernet? i am also confused on if i should use hyper traffic
Administrators Netduma Fraser Posted June 22, 2018 Administrators Posted June 22, 2018 20 mbps down and 2.1 up and yes i am i get 800 + down and 50+ up on my asus ac3100 router my could settings are all 1 it wont let me change them i am also confused on if i should use hyper traffic Was the speed test done through a PC or PS4? As I said, don't need to worry about cloud settings. It'll be on auto & bleeding edge cloud which is what you want. Super turbo mode disables Congestion Control completely so you can't/won't need any of the features on that page.
Nola504 Posted June 22, 2018 Author Posted June 22, 2018 Was the speed test done through a PC or PS4? As I said, don't need to worry about cloud settings. It'll be on auto & bleeding edge cloud which is what you want. Super turbo mode disables Congestion Control completely so you can't/won't need any of the features on that page. i did test on both pc and ps4 i have a gamin pc gtx 1080 16gb ram i7 7700k z270 a pro mobo i hooked old router and get correct speeds i dunno why its gotta be some configuration issue
Administrators Netduma Fraser Posted June 22, 2018 Administrators Posted June 22, 2018 Can you test the WiFi on the R1 please and see if you're getting higher speeds
Nola504 Posted June 22, 2018 Author Posted June 22, 2018 okay i get the same but with a D bufferbloat rating instead of a B
Administrators Netduma Fraser Posted June 22, 2018 Administrators Posted June 22, 2018 Can you do speedtest.net for speed test instead of DSLReports please and see if you get the same results. You don't need to worry about bufferbloat given your high speeds.
JOE1305 Posted June 22, 2018 Posted June 22, 2018 okay i get the same but with a D bufferbloat rating instead of a B do you have 100% download and upload in the congestion control? e.g. for your pc and than the testing
Nola504 Posted June 22, 2018 Author Posted June 22, 2018 okay i have 30.9 down and 3.7 up and yes but it says congestion control is disabled due to super turbo mode
Administrators Netduma Fraser Posted June 22, 2018 Administrators Posted June 22, 2018 Are you using PPPoE by any chance?
Nola504 Posted June 22, 2018 Author Posted June 22, 2018 should i use hyper threading for my pc and ps4?
Administrators Netduma Fraser Posted June 24, 2018 Administrators Posted June 24, 2018 should i use hyper threading for my pc and ps4? Hyper traffic? No as I mentioned your congestion control is disabled due to super turbo mode. Are you using a gig cable connected router to hub and from router to PC?
