JOE1305 Posted April 23, 2018 Posted April 23, 2018 Hello everyone, I really need help for setting up my netduma for ww2. Im living in Austria and actually play on the German Server. But even though I have strict mode on the game always puts me on the server in los angeles. The lag is hillarious. And the second issue I have is that the game cant find lobbies although I set up the geo filter on 600km radius. I see a lotta players but I cant connect to a lobby. Im playing on the cod profile where the CC is on 70/70 and Pingassist at 50ms ping. Thanks in advance. Peace
Netduma Staff Netduma Jack Posted April 23, 2018 Netduma Staff Posted April 23, 2018 Hi Joe, not to worry - let's take a look at these issues. The first one could likely be fixed by setting Ping Assist to 0 as well as keeping Strict Mode on. If Strict Mode is on, it means you cannot connect to anything outside your radius (even dedicated servers) unless their ping is below your Ping Assist threshold. If Ping Assist is on that could be the cause. If Strict Mode is on and Ping Assist is at 0 it is physically impossible to game on any host outside your radius. 600km seems quite small - I'd recommend 1000 - 1500km for the Geo-Filter. Within that range you will still get great ping hosts. 600km will give you issues in finding games. Finding games quickly really depends on where you are located though. Being in Austria I imagine many of the best servers are in Germany and France, and you could still get a great ping in those places if you increase your radius. I hope this helps
JOE1305 Posted April 24, 2018 Author Posted April 24, 2018 Hi Joe, not to worry - let's take a look at these issues. The first one could likely be fixed by setting Ping Assist to 0 as well as keeping Strict Mode on. If Strict Mode is on, it means you cannot connect to anything outside your radius (even dedicated servers) unless their ping is below your Ping Assist threshold. If Ping Assist is on that could be the cause. If Strict Mode is on and Ping Assist is at 0 it is physically impossible to game on any host outside your radius. 600km seems quite small - I'd recommend 1000 - 1500km for the Geo-Filter. Within that range you will still get great ping hosts. 600km will give you issues in finding games. Finding games quickly really depends on where you are located though. Being in Austria I imagine many of the best servers are in Germany and France, and you could still get a great ping in those places if you increase your radius. I hope this helps HI Jack, thanks for your response. I will try your settings this weekend. When Im playing Blops3 600km are quite enough because there are a lot of players in germany. Just in WW2 cant find lobbies although in the game menu it tells me 12 lobbies found and than is on 0 again. I will let you know how it worked. Peace
Netduma Staff Netduma Jack Posted April 24, 2018 Netduma Staff Posted April 24, 2018 HI Jack, thanks for your response. I will try your settings this weekend. When Im playing Blops3 600km are quite enough because there are a lot of players in germany. Just in WW2 cant find lobbies although in the game menu it tells me 12 lobbies found and than is on 0 again. I will let you know how it worked. Peace Alright excellent, I hope those settings work out for you. Please let me know how you get on and I'll try to give you the best advice from there have fun gaming!
JOE1305 Posted April 25, 2018 Author Posted April 25, 2018 Alright excellent, I hope those settings work out for you. Please let me know how you get on and I'll try to give you the best advice from there have fun gaming! HI Jack, i tested your setting advice yesterday and it worked. Thanks buddy . I saved the profile immeditaley on the netduma, so I just have to load it.
