Macca65 Posted March 4, 2018 Posted March 4, 2018 Good tips..... I am slowly getting into Fortnite on PS4. Problem: Is that I get put with USA hosts/servers on 150~200ms ping!
MrTrakky Posted March 4, 2018 Author Posted March 4, 2018 Thanks Macca glad you're getting into it mate. I saw something similar said on one of my other posts
fuzzy clam Posted March 6, 2018 Posted March 6, 2018 Good lord,I was kinda interested to check this game out but damn...it sounds way to confusing to me. But nice video.
MrTrakky Posted March 6, 2018 Author Posted March 6, 2018 Good lord,I was kinda interested to check this game out but damn...it sounds way to confusing to me. But nice video. Give it a go mate it's very addictive
fuzzy clam Posted March 9, 2018 Posted March 9, 2018 Give it a go mate it's very addictive Might have to give it a try...just one problem I don't know where to get it...SMH Is it a hard copy disk, download,etc for PS4 ? I guess that shows how up to date on it I am...
Macca65 Posted March 10, 2018 Posted March 10, 2018 Might have to give it a try...just one problem I don't know where to get it...SMH Is it a hard copy disk, download,etc for PS4 ? I guess that shows how up to date on it I am... Download it from the PS store, and select your server region from the setting in the pre game lobby. Just be aware you have to scroll down until you come to the server selection! As there are quite a lot of settings
Funkybadger Posted March 13, 2018 Posted March 13, 2018 Good tips buddy something I’ve learned is built aggressively in attacks put your opponent under pressure and make him panic
MrTrakky Posted March 14, 2018 Author Posted March 14, 2018 Good tips buddy something I’ve learned is built aggressively in attacks put your opponent under pressure and make him panic definitely mate i've started to use the double ramp strategy works a treat
Funkybadger Posted March 16, 2018 Posted March 16, 2018 definitely mate i've started to use the double ramp strategy works a treat Yep it really does also confidence is key going into a 1v1
