Administrators Netduma Fraser Posted May 14, 2018 Administrators Posted May 14, 2018 Okay interesting, so seemingly disconnecting the Xbox from the router overnight resulted in the connection staying up? Yes we are trying to fix it but need to get information from people having the issue. Some are running debug firmware now. I can send it to you with instructions of what to do if you encounter it again.
Administrators Netduma Fraser Posted May 14, 2018 Administrators Posted May 14, 2018 Would you like the debug firmware?
JACKSDARIPPER Posted May 14, 2018 Author Posted May 14, 2018 Yes if it’s going to fix the problem. I’m still work though
Administrators Netduma Fraser Posted May 14, 2018 Administrators Posted May 14, 2018 Yes if it’s going to fix the problem. I’m still work though It won't fix the issue, its for collecting the data we need to work on a fix.
Administrators Netduma Fraser Posted May 14, 2018 Administrators Posted May 14, 2018 Great thanks, sent you a PM.
JACKSDARIPPER Posted May 14, 2018 Author Posted May 14, 2018 Another question is do you know when will they fix the led reversal for the Ethernet ports because mines don’t match
Administrators Netduma Fraser Posted May 14, 2018 Administrators Posted May 14, 2018 Another question is do you know when will they fix the led reversal for the Ethernet ports because mines don’t match It's not a software fix unfortunately
