ben485 Posted December 15, 2017 Posted December 15, 2017 I may need to buy another power cord. I misplaced it while moving. Where can I buy such a thing, and what info do I need to choose the correct one. I haven't gamed since 2015, so I've had it awhile but haven't used it in some time. Is my router still up to date and usable? Thanks for any information provided.
iAmMoDBoX Posted December 15, 2017 Posted December 15, 2017 I may need to buy another power cord. I misplaced it while moving. Where can I buy such a thing, and what info do I need to choose the correct one. I haven't gamed since 2015, so I've had it awhile but haven't used it in some time. Is my router still up to date and usable? Thanks for any information provided. http://forum.netduma.com/topic/11018-major-netduma-upgrade-now-available-v-1036j/ You need a 12 volt 1 amp plug.
Dan Posted December 15, 2017 Posted December 15, 2017 Detailed upgrade notes available on the website. Do read carefully first. Depending on what version you are on I seem to recall there was an older version that you shouldn't upgrade from. Boot up the router and check your firmware version
abc123 Posted December 15, 2017 Posted December 15, 2017 a long long time ago i bought this https://www.amazon.com/gp/product/B006GEPUYA/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 it works and worked...i can't guarantee it won't completely fry your electronics...but it is all i can suggest. i used to have a post about it but i can't find it...sorry
