need help speed below 60 m!!!!
hi guys
my isp speed is 200 dl, 100 ul
after connecting netduma DL speed drop below 60
even though I did all as recommended in getting full speed in knowledge base forum.
thanks
hi guys
thanks
Click on Congestion Control on the left hand side of the NETDUMA interface and then click on 'Set Bandwidth'. Enter the speeds you pay for in the Internet Connection download and upload boxes. Then click 'Update Bandwidth'.
Screen%20Shot%202016-06-28%20at%2015.06.
A box will appear asking if you want it to automatically set up according to your speeds. Select Yes.
Screen%20Shot%202016-06-24%20at%2013.34.
speed test still below 60 mb
I attached setting and speed test
Reset distribution on the congestion control page for download and upload, make sure share excess is checked.
Already did that and share excess is checked
Do you have turbo mode enabled and are you doing a speed test via ethernet?
Hi Netduma Fraser
Yes i have turbo mode enable and i test with wired connection
Hi Netduma Fraser
Are ALL devices in your home connected to the R1?
Double check everything here:
  • Reactive Algorithm
  • 100% anti-flood sliders
  • Reset device prioritisation
  • Enable share excess
  • Disable IPv6 in both WAN, LAN and miscellaneous
  • Disable deep packet processing in miscellaneous
  • Enable turbo mode in miscellaneous
  • Ensure your ethernet cable is Cat5e+
One you may not have done:
  • Disable anything that is in hyper traffic
Hi Netduma Fraser,
-all devices connected to r1
-all the lists are double checked and nothing in hyper traffic
and i have tried 2 different ways and speed test with wired connection
1, isp router as bridge mode ---------> r1 -----------> all devices
2.isp router as bridge mode-------->rt ac 88u---------->r1-----------> all devices
the result are the same "below 60mb" but without r1 my dl speed is 200+
any help please.
Please post in the 1 on 1 section with dates/times you would be available & I'll take a look. I usually need a days notice.
