help, not resolve yet
I have 200 and 20 tested to make sure, but when I put the netduma in the loop I get 5 and 5 I have done the following, i used to be able to unplug for an hour and get it to work for a couple hours, I have tried everything that people have sugested
Follow this precisely:
  • Input your speeds 200/20, don't allow auto setup.
  • Use reactive algorithm
  • 100% anti-flood
  • Share excess on
  • Reset device prioritization and apply
  • IPv6 disabled in WAN, LAN & misc.
  • Deep packet processing disabled in misc
  • Turbo ticked in misc (go back and enable Super turbo as well if speeds aren't higher after completing these steps)
  • Ensure all devices are connected to the R1 via Ethernet or wifi (if wifi make sure they don't automatically connect to your ISP hub)
  • Do a wired speed test from your PC (ensure your PC is capable of gigabit speeds - check for drivers)
but still the speeds are 5 and 5, no problems until last week that I noticed, seems these problems are only fixed on a 1 on 1 bases, any help would be appreciated
http://forum.netduma.com/topic/22354-slow-speeds-also/?do=findComment&comment=160621
If that doesn't fix it, then I'd say there's about a 5% chance the R1 is broken.
I'll be here for 10/15 minutes after this post, if you'd like I can take a look through teamviewer and see if I can fix it
Download teamviewer here: https://ninite.com/teamviewer12/ninite.exe
There is no need to create another topic to get help as I told you what to do in the last one. Let us know how you got on with MoD's help. If you need my help still then:
Post in the 1 on 1 section with dates/times you're available next week. http://forum.netduma.com/forum/64-1-on-1-support/
Pretty sure it's the modem. I did speed tests on multiple sites and they all had different results. http://speedtest.comcast.netwas consistently giving above 200/20. Also did the DSLreports Puma 6 chipset test which failed miserably since his modem has a Puma 6.
I recommended getting the TC-7610 and dropping his speed to 100/10 since for whatever reason Spectrum will only let you use the 7610 up to 100 Mbps.
Nice one MoD & thanks for helping :)
Thanks for your help last night, the new modem will be here tomorrow and then I will update. Without the netduma on black ops 3 ps4 the opponent is already shooting at me when I see them it sucks, where do you guys recommend buying another netduma, I need one for another location
How do you mean? You can purchase from our website or Amazon.
Well normally I average 3rd (bo3-ps4) with netduma, since at the present time I am having problems with the netduma I am using a regular router, and I am at the bottom almost every game, seems throttling to 15m down and 1 up really helps what are you thoughts on that? are there official recommended settings for a netduma for (bo3-ps4)
Okay I have the new modem you suggested installed ---I lowered my speed to 100/10 and still have the same problem? alright guys where are you at, I am getting killed here, its Saturday night you should be online :)
