Netduma Router is Cutting My Speed in Half (2017)
More than half actually
With Netduma = 50-60 down and 50+ up
Without Netduma = 188 down and 100+ up
Please help! :(
Did everthing but the last option:
If the speeds are still low, please disable IPv6 (located in WAN, LAN & miscellaneous settings) on the NETDUMA router. You may need to restart your modem after applying these settings.
It isn't enabled in the first place. Should I?
Enter the speeds you pay for in the Internet Connection download and upload boxes. Then click 'Update Bandwidth'.
Screen%20Shot%202016-06-28%20at%2015.06.
A box will appear asking if you want it to automatically set up according to your speeds. Select Yes.
Screen%20Shot%202016-06-24%20at%2013.34.
  • 3 weeks later...
