setting up on sky fibre
hi i changed my isp from bt to sky fibre can someone point me in the direction of how to set up the duma for sky thanks
Should just be plug in and go unless it require MER authentication or PPPoE. Can you just plug in and go? If so then just do the DMZ as before, disable it's WiFi and connect everything through the Duma.
