Loumano31589 Posted August 12, 2017 Posted August 12, 2017 I am having problems with my settings saving. I have enabled the cookies on the NetDuma but everytime i reboot my router they will always change to the default. I have made sure my cookies for google are enabled for NetDuma as well. I have never had this problem before until i factory reset my router. Please any help would be much appreciated. Thank you
PharmDawgg Posted August 12, 2017 Posted August 12, 2017 I would recommend accessing the R1 gui and then hard resetting the browser you’re using. I would recommend using chrome if you are not already. Then go into the setting on the R1 and select enable cookies. Then reboot the router. Go back into the R1 settings to verfiy your selections have held.
Administrators Netduma Fraser Posted August 13, 2017 Administrators Posted August 13, 2017 Set it all up then reboot from miscellaneous settings and should save. If you were unplugging it that's likely the reason.
