upnatom Posted July 13, 2017 Posted July 13, 2017 Iv factory reset the router....it has H firmware already..... set my bandwidth back to what im supposed to get. But when i go to dsl reports it doesnt pass the 50mbs.(i pay for 100mbps) but i have another router i use just for wifi and i get way over 100mbps test on wifi
pollutionblues Posted July 14, 2017 Posted July 14, 2017 The guide for getting your full speed is here: http://support.netduma.com/en/support/solutions/articles/16000022366-why-is-my-connection-speed-lower- Also double check these settings: Make sure the Reactive Algorithm is selected Set anti-flood sliders to 100% Disable IPv6 in both WAN, LAN and miscellaneous Disable deep packet processing in miscellaneous Ensure your ethernet cable Cat5e+ Do a wired speed test from a PC
Netduma Staff Netduma Jack Posted July 14, 2017 Netduma Staff Posted July 14, 2017 Iv factory reset the router....it has H firmware already..... set my bandwidth back to what im supposed to get. But when i go to dsl reports it doesnt pass the 50mbs.(i pay for 100mbps) but i have another router i use just for wifi and i get way over 100mbps test on wifi Welcome to the forum - PollutionBlues has given some great suggestions above so try those settings. We literally just helped someone out with the same issue - even the same speeds weirdly, and he's now getting 95mbps download. It just takes the right settings
