HaitianFromMars Posted July 1, 2017 Posted July 1, 2017 if someone could help me setting ip vanish vpn. thanks .
Administrators Netduma Fraser Posted July 1, 2017 Administrators Posted July 1, 2017 If you post the OpenVPN configuration file here I can amend it for you
HaitianFromMars Posted July 1, 2017 Author Posted July 1, 2017 client dev tun proto udp remote nyc-a21.ipvanish.com 443 resolv-retry infinite nobind persist-key persist-tun persist-remote-ip ca ca.ipvanish.com.crt verify-x509-name nyc-a21.ipvanish.com name auth-user-pass comp-lzo verb 3 auth SHA256 cipher AES-256-CBC keysize 256 tls-cipher TLS-DHE-RSA-WITH-AES-256-CBC-SHA:TLS-DHE-DSS-WITH-AES-256-CBC-SHA:TLS-RSA-WITH-AES-256-CBC-SHA all their config files look like that and its not working.
HaitianFromMars Posted July 1, 2017 Author Posted July 1, 2017 okay i got it to work but why am i only getting like 10 down and 9 up when my actual speed is 940/880 . please can someone help with that
Administrators Netduma Fraser Posted July 2, 2017 Administrators Posted July 2, 2017 The VPN feature is limited to around ~10mbps because of hardware. It was created for gamers so 10mbps is plenty for gaming & protecting yourself.
KingProdigy Posted August 13, 2017 Posted August 13, 2017 So just to be clear, I got this all to connect and it seems to be working fine, just to ensure I did it right, does the below look fine? I couldn't find the top part anywhere so I used what you linked above. Ca cert was on the site, no clue where the openvpn config file was.. could you link me it / check to see if this looks right? Thanks. client dev tun proto udp remote chi-a48.ipvanish.com 443 resolv-retry infinite nobind persist-key persist-tun persist-remote-ip ca ca.ipvanish.com.crt verify-x509-name chi-a48.ipvanish.com name auth-user-pass comp-lzo verb 3 auth SHA256 cipher AES-256-CBC keysize 256 tls-cipher TLS-DHE-RSA-WITH-AES-256-CBC-SHA:TLS-DHE-DSS-WITH-AES-256-CBC-SHA:TLS-RSA-WITH-AES-256-CBC-SHA <ca> -----BEGIN CERTIFICATE----- MIIErTCCA5WgAwIBAgIJAMYKzSS8uPKDMA0GCSqGSIb3DQEBDQUAMIGVMQswCQYD VQQGEwJVUzELMAkGA1UECBMCRkwxFDASBgNVBAcTC1dpbnRlciBQYXJrMREwDwYD VQQKEwhJUFZhbmlzaDEVMBMGA1UECxMMSVBWYW5pc2ggVlBOMRQwEgYDVQQDEwtJ UFZhbmlzaCBDQTEjMCEGCSqGSIb3DQEJARYUc3VwcG9ydEBpcHZhbmlzaC5jb20w HhcNMTIwMTExMTkzMjIwWhcNMjgxMTAyMTkzMjIwWjCBlTELMAkGA1UEBhMCVVMx CzAJBgNVBAgTAkZMMRQwEgYDVQQHEwtXaW50ZXIgUGFyazERMA8GA1UEChMISVBW YW5pc2gxFTATBgNVBAsTDElQVmFuaXNoIFZQTjEUMBIGA1UEAxMLSVBWYW5pc2gg Q0ExIzAhBgkqhkiG9w0BCQEWFHN1cHBvcnRAaXB2YW5pc2guY29tMIIBIjANBgkq hkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAt9DBWNr/IKOuY3TmDP5x7vYZR0DGxLbX U8TyAzBbjUtFFMbhxlHiXVQrZHmgzih94x7BgXM7tWpmMKYVb+gNaqMdWE680Qm3 nOwmhy/dulXDkEHAwD05i/iTx4ZaUdtV2vsKBxRg1vdC4AEiwD7bqV4HOi13xcG9 71aQ55Mj1KeCdA0aNvpat1LWx2jjWxsfI8s2Lv5Fkoi1HO1+vTnnaEsJZrBgAkLX pItqP29Lik3/OBIvkBIxlKrhiVPixE5qNiD+eSPirsmROvsyIonoJtuY4Dw5K6pc NlKyYiwo1IOFYU3YxffwFJk+bSW4WVBhsdf5dGxq/uOHmuz5gdwxCwIDAQABo4H9 MIH6MAwGA1UdEwQFMAMBAf8wHQYDVR0OBBYEFEv9FCWJHefBcIPX9p8RHCVOGe6u MIHKBgNVHSMEgcIwgb+AFEv9FCWJHefBcIPX9p8RHCVOGe6uoYGbpIGYMIGVMQsw CQYDVQQGEwJVUzELMAkGA1UECBMCRkwxFDASBgNVBAcTC1dpbnRlciBQYXJrMREw DwYDVQQKEwhJUFZhbmlzaDEVMBMGA1UECxMMSVBWYW5pc2ggVlBOMRQwEgYDVQQD EwtJUFZhbmlzaCBDQTEjMCEGCSqGSIb3DQEJARYUc3VwcG9ydEBpcHZhbmlzaC5j b22CCQDGCs0kvLjygzANBgkqhkiG9w0BAQ0FAAOCAQEAI2dkh/43ksV2fdYpVGhY aFZPVqCJoToCez0IvOmLeLGzow+EOSrY508oyjYeNP4VJEjApqo0NrMbKl8g/8bp LBcotOCF1c1HZ+y9v7648uumh01SMjsbBeHOuQcLb+7gX6c0pEmxWv8qj5JiW3/1 L1bktnjW5Yp5oFkFSMXjOnIoYKHyKLjN2jtwH6XowUNYpg4qVtKU0CXPdOznWcd9 /zSfa393HwJPeeVLbKYaFMC4IEbIUmKYtWyoJ9pJ58smU3pWsHZUg9Zc0LZZNjkN lBdQSLmUHAJ33Bd7pJS0JQeiWviC+4UTmzEWRKa7pDGnYRYNu2cUo0/voStphv8E VA== -----END CERTIFICATE----- </ca>
Administrators Netduma Fraser Posted August 14, 2017 Administrators Posted August 14, 2017 If it's working with this config that's great. Best way to double check it's working is check your public IP before and after on the device you've VPN'd.
