Administrators Netduma Fraser Posted August 14, 2017 Administrators Posted August 14, 2017 struggling to paste screenshot, Take a look here, mentions how to upload it.
graeme Posted August 14, 2017 Author Posted August 14, 2017 iv uploaded to you via netduma upload ,it says uploaded to your host
Administrators Netduma Fraser Posted August 14, 2017 Administrators Posted August 14, 2017 Okay that all looks fine. In that case it appears to be the closest Speed test server to you that has some issues with high ping & fluctuations. Recommend testing from a different server in future, should be able to get near enough full speeds with the settings I left it on if I recall correctly. iv uploaded to you via netduma upload ,it says uploaded to your host It uploads it then gives you links to use to show people, we don't see it otherwise
graeme Posted August 14, 2017 Author Posted August 14, 2017 Cheers thanks for all your help . Really appreciate it.
