3zo000oz Posted June 3, 2017 Posted June 3, 2017 hi i have my speed dropped idk why, i have 300 down and 150 up now i can't get more than 70 down and up everything is set correctly i had this problem before and a reboot fixed it but now even factory reset didn't work
3zo000oz Posted June 3, 2017 Author Posted June 3, 2017 i have tried another router and i got my full speed the problem with my duma but idk what it is
XSXS Posted June 3, 2017 Posted June 3, 2017 Hmm, leave the Netduma powered on. Then disconnect it from your modem, wait an hour or so. Reconnect it and reboot everything so the duma is the main router. Test your speeds and report back. If still disconnected, hook it back up and run a speed test. My reasoning is, with my old modern, my speeds would slowly drop. No matter what i would do the speeds would never be normal. A couple of times i disconnected the Netduma from my modem for other reasons and both times when i reconnected the duma i would get my normal speeds. Odd? Ikr!
3zo000oz Posted June 3, 2017 Author Posted June 3, 2017 Hmm, leave the Netduma powered on. Then disconnect it from your modem, wait an hour or so. Reconnect it and reboot everything so the duma is the main router. Test your speeds and report back. If still disconnected, hook it back up and run a speed test. My reasoning is, with my old modern, my speeds would slowly drop. No matter what i would do the speeds would never be normal. A couple of times i disconnected the Netduma from my modem for other reasons and both times when i reconnected the duma i would get my normal speeds. Odd? Ikr! ok that worked very easy solution and i only unplug it for 3 mins thanks man
XSXS Posted June 3, 2017 Posted June 3, 2017 Cool! So i was not seeing things, lol. I wonder why this fixes it....
Administrators Netduma Fraser Posted June 4, 2017 Administrators Posted June 4, 2017 Thanks for the tip, not sure why that occurs but will look at that for DumaOS.
