Best replacement for bt homehub 4??
Anyone recommend a replacement for the bt homehub 4? Its going to connect to the duma.
One that is reliable please...thanks in advance.
Bazza.
if your cabinet is eci then get a draytek or any modem with a lantiq (infineon) chipset or if it is hauwei then get a broadcom chipset modem.
draytek vigor 130 eci (lantiq/infineon).
openreach hg612 (broadcom).
oh, by the way, those are for modems only, not modem/routers! If the duma is connecting to it then theres no problem as all you need to do is input your pppoe details if you know them. If it is bt then it is the following:
username:                 [email protected]
password:                  anything you like just so long as the box is not empty!
