Jettman Posted March 30, 2017 Posted March 30, 2017 ok so i just upgraded my internet to 100 down/40 up. for a few hours i was only getting 50 down and 20 up then i rebooted my netgear nighthawk to see if it would give me the right speeds. it did and gave me like 93 down/32 up so i was pretty happy. i unplugged a cable to try cat6a with the dsl cable to try get better speeds/ ping but the cable wouldnt fit, so i went plugged eveything back to normal, rebooted the modem/router but it went back to the old speeds 50/20 and now im stuck and cant get it back to round about 90/30........ any help need it fast
Administrators Netduma Fraser Posted March 30, 2017 Administrators Posted March 30, 2017 Reactive Algorithm100% anti-floodShare excess enabledReset device prioritisation & applyDisable IPv6 in WAN, LAN & miscDisable deep packet in miscEnable turbo modeEnsure the ethernet cables you're using connecting the R1 to hub & R1 to PC are Cat5e+/can handle your speeds.Do a wired speed test from a PC
