i have moderate nat i have tried following other posts please help
i have virgin hub 3.0 cable connected to duma than duma have cable to my console, i have tried the upnp put duma dmz etc but still getting moderate nat
i tried virgin hub to console and put my ps4 dmz and nat was open . please help
Hard turn off the console
Disable Geo-filter on Duma
Hub in modem mode (recommended) or R1 WAN IP from device manager into the DMZ on hub
UPnP & port forwarding disabled on the hub
UPnP OR port forwarding enabled on the Duma, not both
UPnP forwarding disabled in Duma miscellaneous settings
Boot up console - check network settings - should be open or NAT Type 2 (open)
Boot up game - should be open
If port forwarding:
80 UDP/TCP
443 UDP/TCP
1935 UDP/TCP
3074 UDP/TCP
3478-3480 UDP/TCP
thanks for replying.
i just port forward 3074 and 3075 and nat is open now.
note i still have upnp on and my virgin router and duma and have enable upnp fowarding ticked bit have still managed to get black ops 3 nat open.
