F3arless27 Posted February 15, 2017 Posted February 15, 2017 the dedicated servers are rediculous im in texas getting texas host and its still aweful there has got to be something going on please i request 1 on 1 to get this resolved ive done everything all my test are fine execept for dslreport the bluffer bloat is always aweful get either f or c the piing is low 30's but still aweful hit reg with Congestion halo 5 profile enabled
Administrators Netduma Fraser Posted February 16, 2017 Administrators Posted February 16, 2017 Are ALL devices connected to the Netduma? Do not worry about bufferbloat, have anti-flood on 70/70, it will prevent buffer bloat if your line is saturated. Do you have your console in hyper traffic? Is your ping to the game fluctuating a lot? Temp ban the server/move your location to another area and force different servers, do you have a better experience?
F3arless27 Posted February 16, 2017 Author Posted February 16, 2017 So i can move my home location and it might help with servers? yes console is in hyper traffic and Ill temp ban the server and then get it again? it doesn't seem to be fluctuating im hoping Duma OS will help with this its my biggest issue i just want good Halo Gameplay its so important for me Im a very Competitive person and i lose alot of my fights cause of the connection.
yumyumitup Posted February 25, 2017 Posted February 25, 2017 I am in Dallas and I agree that the Texas Servers feel awful. I do not understand why. It's like I get no autoaim or magnetism when I am on the Texas server and the other team can eat multiple headshots when no shfields. If I set my location to the Midwest and get the St. Louis or Iowa Servers, the gameplay is much better. I can't tell if this is the Netduma, or just the San Antonio Azure server being trash. But I am glad to hear this is not just in my head.
F3arless27 Posted February 25, 2017 Author Posted February 25, 2017 yumyumitup where exactly do you put your home location i want to try
F3arless27 Posted February 27, 2017 Author Posted February 27, 2017 Yes my ping has been fluctuating aswell base ping how can i fix that?
Administrators Netduma Fraser Posted February 27, 2017 Administrators Posted February 27, 2017 That test indicates issues with your line so if it's fluctuating that is someone you would need to take up with your ISP. However, it could just be the Google servers misbehaving as they sometimes do. So would recommend running a PingPlotter test to a local website/at least one in the country.
F3arless27 Posted February 27, 2017 Author Posted February 27, 2017 these are my ping plotter results from texas to google where ever that is located
F3arless27 Posted February 27, 2017 Author Posted February 27, 2017 how do i fix whatever is going on with my line i want the best gameplay availible
Administrators Netduma Fraser Posted February 28, 2017 Administrators Posted February 28, 2017 Don't do the Google servers, as I said they could be misbehaving. Do a different site. If you see something similar then it is a problem with your line and therefore you will need to take it up with your ISP as it is out of your hands.
