omega4 Posted December 19, 2016 Posted December 19, 2016 Is there a difference between selecting Setttings/Miscellaneous/"Enable UPnP Forwarding" vs. selecting Settings/UPnP/Checking the "Enable" box? Do you have to perform the latter action first (checking the UPnP "enable" box) in order to do the former action (enable UPnP Forwarding)? Does enabling UPnP Forwarding automatically turn on UPnP (checks the "enable" box automatically for you)? Thanks.
iAmMoDBoX Posted December 19, 2016 Posted December 19, 2016 UPnP Forwarding is if you're Netduma is first plugged into another router and not in the DMZ of it. It will forward which ports to open to the other router so you will have open NAT. For example, your ISP modem/router combo and your Netduma plugged into that.
Administrators Netduma Fraser Posted December 19, 2016 Administrators Posted December 19, 2016 As above ^
omega4 Posted December 19, 2016 Author Posted December 19, 2016 UPnP Forwarding is if you're Netduma is first plugged into another router and not in the DMZ of it. It will forward which ports to open to the other router so you will have open NAT. For example, your ISP modem/router combo and your Netduma plugged into that. As above ^ Thank you gentlemen. Since my Netduma router is the only router in use (connected directly to my modem), then it appears UPnP Forwarding doesn't apply in my case.
Administrators Netduma Fraser Posted December 19, 2016 Administrators Posted December 19, 2016 I'll now close your thread as your question has been answered. Feel free to open another if needed.
