ESLmakesNOISE Posted November 27, 2016 Posted November 27, 2016 I just purchased a new 4k smart tv and now notice the duma makes a "processing" noise while streaming Netflix via Wi-Fi. It's loud enough to hear over the tv and quite annoying. Any ideas on a cause or fix?
iAmMoDBoX Posted November 27, 2016 Posted November 27, 2016 That's the processor going... It's normal and there's really no fix, although it shouldn't be that loud to drown out a tv
Administrators Netduma Fraser Posted November 28, 2016 Administrators Posted November 28, 2016 As above. Is it located on a surface where it may not be getting enough air flow? Such as a carpet?
ESLmakesNOISE Posted November 28, 2016 Author Posted November 28, 2016 No Sir, it's on a hard flat surface with plenty of airflow
