shuking99 Posted November 10, 2016 Posted November 10, 2016 I don't know the channel to use in netduma because i can't use internet by wifi.I used a program called wife analyzer and it says that the best channel is the 14th when it isn't in the page.Also i tried to use other channels (i tried all of them) and is so bad T.T.When i entered the program said that the channels were goos but it still bad.PLS i need help T.T
RedBull2k Posted November 10, 2016 Posted November 10, 2016 Go knock on their door and ask them to change their channel, or if you can't/they wont. Then channel 1 will prob be the most congested so try each one, by one.
Administrators Netduma Fraser Posted November 15, 2016 Administrators Posted November 15, 2016 Hey, welcome to the forum! Use the second best channel the analyser tells you. The issue you're having I imagine is with speeds? If so follow this guide please: http://support.netduma.com/support/solutions/articles/16000022366-why-is-my-connection-speed-lower-
