Speed test low
I I have set up my router and I get low speed test. My up/download from modem to computer is 5/100. From old router to computer 5/100. From R1 to computer 1/20. All of these are hardwired. What do I do?
Guest Steven
I did what they recommended on that link and I get the same results.
Guest Steven
So I got it to 5 up and 23 down I am supposed to have 100 down.
Sliders set to 100% deep packet inspection off , ipv6 off in all sections?
Can you tell us the version number you are on ? If it is not 1.03.4 could you update via the upgrade tab if that does not work here is the link to do it manualy
http://wiki.netduma.com/doku.php?id=manual_update
If it is 1.03.4 and you have done all the suggestion could you take screen shots of all the set up pages and post them here for one of us to help thank you :)
If you follow the instructions in the speed link Zennon posted( http://wiki.netduma.com/doku.php?id=why_is_my_speed_lower&s%5B%5D=speed) you can get upto 120+ mbits. I did a raw test myself & got 180mbits. But at the very least 120mbits is the minimum.
Make sure your device prio is also reset, that often catches people out.
That fact you're getting around 25 leads me to believe you haven't disabled IPv6 fully.
