OVIDIU SALAGEAN Posted October 26, 2016 Author Posted October 26, 2016 i have 200 mb donw speed in my hub 3.0 virgin media router and when i plug r 1 in my speed go to 5mb i test whit oakla speed test i play call of duty black ops 3 so my bandwhit is around 4000 but when is plug r 1 i have only 130 myu game lag and my ping go 999 and many tiem disconect after and i cant even open google or thsi formu page when r1 is on
Administrators Netduma Fraser Posted October 26, 2016 Administrators Posted October 26, 2016 Hello, welcome to the forum! It does sound like you have internet through the R1 if you are able to do a speed test so we will solve your speed and lag issues first. Please follow this for your speeds: Reactive Algorithm 100% anti-flood Share excess enabled Reset device prioritisation & apply Disable IPv6 in WAN, LAN & misc Disable deep packet in misc Enable turbo mode Ensure the ethernet cables you're using connecting the R1 to hub & R1 to PC are Cat5e+/can handle your speeds. Do a wired speed test from a PC For Lag, please follow this guide and provide us with the screenshots asked for: http://support.netduma.com/support/solutions/articles/16000022425-lag-support-instructions-to-post-on-the-forum-
