SuperJ380 Posted October 22, 2016 Author Posted October 22, 2016 If I could I would send you a screen shot! My feo-filter is 540 miles and ping at 30
SuperJ380 Posted October 22, 2016 Author Posted October 22, 2016 yeah i got cable internet also will this work for me. i have mine at 540 mile and mine ping at 30 in texans
SuperJ380 Posted October 22, 2016 Author Posted October 22, 2016 Okay so put my location out in the ocean and just have my ping were I have it at 30. I will try this but I don't think that fix my issue though. I will try this tomorrow and what Buck Nasssty said
Slipknot31286sic6 Posted October 22, 2016 Posted October 22, 2016 He is using Cod ultimate profile like myself. But moved ping lower than 50
Administrators Netduma Fraser Posted October 22, 2016 Administrators Posted October 22, 2016 Firstly make sure your console is connected via automatic network settings. On the duma make sure you haven't changed anything like MTU in WAN/LAN and if so change back to automatic. See if that resolves it, otherwise can you see if you get the same issues directly connected to your modem please.
SuperJ380 Posted October 23, 2016 Author Posted October 23, 2016 But I haven't touched that at all it shows that it's Enabled is that how it's supposed to be
SuperJ380 Posted October 23, 2016 Author Posted October 23, 2016 And I'm trying that Cod Ultimate Profile with my location out in the ocean and my ping at 30 but I'm not getting any lobby's. How does it work on this profile
SuperJ380 Posted October 23, 2016 Author Posted October 23, 2016 I'm sorry but what do you mean via automatic in my network settings. I'm on my XboxOne where do I find "via" at cause I don't see it on here. I only see IP setting and DNS setting in my network settings
Slipknot31286sic6 Posted October 23, 2016 Posted October 23, 2016 Put the ping at 45 or 50 if u don't have a close server by u. As it will only find ppl from all over who meet that ping criteria
Administrators Netduma Fraser Posted October 23, 2016 Administrators Posted October 23, 2016 I'm sorry but what do you mean via automatic in my network settings. I'm on my XboxOne where do I find "via" at cause I don't see it on here. I only see IP setting and DNS setting in my network settings When you go to setup the network to connect to just let it do it all automatically and don't set anything manually.
