Huthayfa Posted October 14, 2016 Posted October 14, 2016 Hello everyone, good afternoon. today I am pushing through my ONT settings heavily to get my setup work as I want. Objective: I want to set my Fiber ONT Model Nokia G-240w-B to full bridge mode letting it passing the connection to the Netduma, in order for the Duma to be assigned with public ip address of WAN. there are two problems: 1- the PPPoE connection of my ISP requires 801P.Q Vlan tagging, which I think yet is not supported by the Netduma 2- when I set PPPoE connection on this new version of ONT (G-240w- B to my previous Linksys E1700 -which supports 801P.Q tagging- the connection does work. however, with less than half of the speed < 80 Mbps (( the previous ONT I-240w-A was getting me full speed through PPPoE bridge mode)) Good news: I am Actually half way toward my goal, I has access to the ONT telnet commands, It is linux BusyBox 1.16 version, there many Interfaces belong to the PON service, Ethernet, WLAN and a lot of things. what I found useful is that Ethernet interface br0 > eth0.0 is assigned to vlan 0 , I want to change it is name to eth0.881 assigned to VLAN 881 for the connection to work, however, I don't know the command to do that , I hope someone technically advanced to help. I know it is a lot of technical jargon, But I had to clarify my procedure for better help chance! thanks
Administrators Netduma Fraser Posted October 16, 2016 Administrators Posted October 16, 2016 This little guide may help you under VLAN support http://www.stlinux.com/howto/network/short-guide You can add a VLAN tag on the duma, I assume you have tried this?
Huthayfa Posted October 17, 2016 Author Posted October 17, 2016 This little guide may help you under VLAN support http://www.stlinux.com/howto/network/short-guide You can add a VLAN tag on the duma, I assume you have tried this? Thank you Mr. Fraser, yes, I have tried to add vlan tag through the duma, but didn't connect to internet. I will have a lool over the link you gave thanks
Huthayfa Posted October 19, 2016 Author Posted October 19, 2016 This little guide may help you under VLAN support http://www.stlinux.com/howto/network/short-guide You can add a VLAN tag on the duma, I assume you have tried this? Hello Mr. Fraser I am finished with all options of setting VLAN ID. I need to set PPPoE on the Duma , please help thank you.
Administrators Netduma Fraser Posted October 20, 2016 Administrators Posted October 20, 2016 All you need to do is enter the username (usually an email address) & the password into the duma and apply, then reboot the R1 from misc settings and you should be good to go.
Huthayfa Posted October 20, 2016 Author Posted October 20, 2016 All you need to do is enter the username (usually an email address) & the password into the duma and apply, then reboot the R1 from misc settings and you should be good to go. thank you Mr. Fraser, that would work if my connection didn't require a VLAN. the PPPoE connection do require a VLAN ID, VLAN PRI , that is why the problem exist. I will call my isp and see if they can disable the VLAN. thanks
