Axeman747 Posted October 7, 2016 Posted October 7, 2016 I am not sure if this is a netduma, modem, or internet problem. First my setup is - Netgear CM600 cable modem - Netduma - 32 port switch. Now my problem, everyday sometimes twice a day I have to reset the router and modem because my speeds drop from 50mbs to 1-2mbs. After the reset everything is fine. Could sure use some insight as to what the problem could be.
Slipknot31286sic6 Posted October 7, 2016 Posted October 7, 2016 Reactive set in congestion Control and turbo mode selected? Deep packet processing off, ip6 off. Manually put in your speeds as well
PharmDawgg Posted October 7, 2016 Posted October 7, 2016 Please search the forums. From what you are describing it sounds like what was happening the the Motorola/Arris modems SB6183 with the EE bug.
Axeman747 Posted October 7, 2016 Author Posted October 7, 2016 Thanks I'll search EE bug. I have all those settings now, the only difference is preemptive instead of reactive.
Slipknot31286sic6 Posted October 7, 2016 Posted October 7, 2016 No you want reactive u don't want preemptive. That's for ppl with extremely bad Internet.
Administrators Netduma Fraser Posted October 10, 2016 Administrators Posted October 10, 2016 For your speeds: Preemptive/Reactive Algorithm should be able to get full speed with either 100% anti-flood Share excess enabled Reset device prioritisation & apply Disable IPv6 in WAN, LAN & misc Disable deep packet in misc Do a wired speed test from a PC Let us know how you get on
Axeman747 Posted October 10, 2016 Author Posted October 10, 2016 Thanks Fraser. I set all your settings and I will let you know how it works.
