theseus33 Posted September 12, 2016 Posted September 12, 2016 My r1 is running slow. Changing settings, changing pages, doesnt matter. Takes forever. Thought it might be an upgrade issue, cause i have v6g, but wont allow me to upgrade to v6h. I get the following... Upgrade failed. Firmware already installed. With exitcode 1. Any help please?
Administrators Netduma Fraser Posted September 13, 2016 Administrators Posted September 13, 2016 How are you trying to upgrade it? The .6h upgrade file isn't publicly available so I assume by the error message that you're trying to upgrade to .6h using the .6g upgrade file? The only difference between g & h is a slight EULA change, that's all. You're not missing out on any features by being on 6g. Make sure you're using Chrome/Firefox as the browser and that you're using the default them on the router.
