Ps4 login problem
Hello guys
I have a problem signing in my ps4 everytime i get this error nw-31456-9
Is this something to do with my duma?
I tried to factory reset the duma but same problem
Thanks
That PS error is a... cannot connect to the server with in the time limit error,do you have more than one router in your set up ?
If you do...enter your router's page in browser (not the duma) your other router and log in.
Select Advance Menu
Select Firewall settings from menu on left side
Check enable DMZ host
Enter DMZ IP address (your PS4 ID)
Click save settings
Connect to internet manually through your PS4 and put your settings...
Subnet Mask
Default Gateway
IP Address
Primary DNS
Secondary DNS
This was taken from PSN forums and I guess it has fixed the issue for some people but your milage may vary
If it wasn't working with Geo off then it acts like a normal router. So sounds like you experienced the downtime explained above. Are you still having this issue?
