ahmedthiga Posted July 28, 2016 Posted July 28, 2016 @NETDUMA ihave problem when i join to some lobby in black ops3 ,alot of gamer tag doesn't appear on ps4
A7Legit Posted July 28, 2016 Posted July 28, 2016 Can you take a picture of what you mean because I do not understand.
ahmedthiga Posted July 28, 2016 Author Posted July 28, 2016 they're joining but gamertags don't appear?
Administrators Netduma Fraser Posted July 28, 2016 Administrators Posted July 28, 2016 Right okay, I'm not sure if this is a connection issue or not. Has anyone else experienced this?
A7Legit Posted July 28, 2016 Posted July 28, 2016 Right okay, I'm not sure if this is a connection issue or not. Has anyone else experienced this?Maybe I'm just very sleepy but I still don't understand the issue he faces in BO3... Maybe you can explain it to me and dumb it down please
ahmedthiga Posted July 28, 2016 Author Posted July 28, 2016 When i disable the host filter it's back normal
Administrators Netduma Fraser Posted July 28, 2016 Administrators Posted July 28, 2016 Maybe I'm just very sleepy but I still don't understand the issue he faces in BO3... Maybe you can explain it to me and dumb it down please Someone joins the lobby i.e. can see their rank etc but GTs don't show up ------- When i disable the host filter it's back normal Does anything appear blocked on the map when this occurs?
ahmedthiga Posted July 29, 2016 Author Posted July 29, 2016 When i join the lobby instead i see gts iam seeing (searching for other player ) example like iam the host and no one joning to me :like this isee
Administrators Netduma Fraser Posted July 29, 2016 Administrators Posted July 29, 2016 That makes sense. That's likely due to your location, you will need to expand your radius more to allow more local people to connect
