TanYannAn Posted July 19, 2016 Posted July 19, 2016 I have received my R1 last week, been searching up and down for local settings (Malaysia) of my ISP modem and router but it seems like it is returning no result that can actually help me to use my R1. My current ISP provided me with the following for internet connection: Huawei EchoLife HG8240 (GPON terminal) --> Technicolor TG784n V3 Some reference I have searched, wanted to use this method but my GPON terminal is locked out. https://bizstech.zendesk.com/entries/51998465-Connect-to-Maxis-Fibre-using-Custom-Router-Guidelines-Maxis- The Technicolor is currently hosting all my LAN and WIFI connection. I have originally wanted to replace it directly with my R1 but apparently Huawei is not 'talking' to my R1, I guess this could be due to ISP lock out. Now my best option is to have my R1 setup like this: Huawei --> Technicolor --> R1 (host all my LAN and WIFI here) Tried this, but every time I connect my R1 to Technicolor, the internet will disconnect. Unplug R1, internet is fine again. Any solutions? Or any methods I could try?
maazsk97 Posted July 19, 2016 Posted July 19, 2016 Connect the R1 to the ISP modem and connect a pc to the R1 through ethernet cable and right click and select troubleshoot problems on the ethernet icon on the taskbar on the pc.
Administrators Netduma Fraser Posted July 19, 2016 Administrators Posted July 19, 2016 Hey Tan, do you know if you need PPPoE? If it's similar to the link you provided then you do. In which case you will need to put that info into the duma, then the technicolor and R1 should be able to communicate.
