diablo Posted June 13, 2016 Posted June 13, 2016 hello to all someone is kind enough to help me configure the most of netduma PC bo3 I have a Vodafone FTTC fiber connection 65 mb download and 18 upload I connected via netduma DMZ router Vodafone Revolution is everything works correctly I would like to know what to enable and disable the various screens netduma settings? I can also do that players connect me to play? thank you all
Administrators Netduma Fraser Posted June 13, 2016 Administrators Posted June 13, 2016 Hey, welcome to the forum! To get started, put your speeds into bandwidth settings and allow it to auto update. Then try one of the CoD profiles, this will setup everything to play the game. Ensure you're using the Xbox Live Geo-filter service for your PC.
diablo Posted June 14, 2016 Author Posted June 14, 2016 I do not understand the band's why I set 65MB to download and 18 upload but when I do the speedtest in download the result is 18mb and upload speed remains at around 15-16 mb also setting the 100% and as if my line he had a cap
Netduma Staff Netduma Crossy Posted June 14, 2016 Netduma Staff Posted June 14, 2016 What speeds do you get on a speed test directly through your ISP modem/router. Can you post a link to a speed test done through the modem and one done through the Netduma.
Administrators Netduma Fraser Posted June 14, 2016 Administrators Posted June 14, 2016 Please try the following: Reactive Algorithm 100% anti-flood Share excess enabled Reset device prioritisation & apply Disable IPv6 in WAN, LAN & misc Disable deep packet in misc Do a wired speed test from a PC
diablo Posted June 14, 2016 Author Posted June 14, 2016 ok thanks a lot for help I solved the problem on the connection now ask you an additional aid but which profile should I use for code using your PC? you can become a host? if you like? thank you ok thanks a lot for help I solved the problem on the connection now ask you an additional aid but which profile should I use for code using your PC and you can become a host? thank you
Administrators Netduma Fraser Posted June 15, 2016 Administrators Posted June 15, 2016 There is no specific profile for PC CoD. However, you can use any of the CoD profiles. Just make sure on the Geo-filter/Hyper traffic that you choose PC as the device and Xbox Live as the service. We can't force you to become host.
