Hyper-traffic help plz
Hey guys, long time no see. Took a break from COD for a few months so now Im back grinding,and was wondering how can said topic help me?
What's the best way to use for me.
Cable modem > Duma (Xbox and Netgear goes through wired) > Netgear router (all other traffic here)
Ppl have been sponging way to much for my liking so idk if this can or will help.
Included pics of what I run with.
Hi Parkrrr,
nice to see you again.
I'd use the Netduma for all of my traffic unless you need more powerful wifi.
But again, the congestion control is very valueable and shouldn't be wasted.
You can benefit the most if you run all of your devices through your Netduma.
This prevents congestion in your network and helps to keep your gaming smooth.
When it comes to the hyper-traffic settings then I would use XBOX Live as service,
because this covers all possible output ports and not just the CoD port UDP 3074.
Sincerely, Kay.
Hey Parkrrr, I would put the upload anti-flood at 70%, xbox live in the hyper traffic service instead of the ports. Could also do Geo-filter PA 0, distance 1000km.
Will do. I'll try that tonight after work!
