yosu888 Posted May 7, 2016 Posted May 7, 2016 Hi. the other day I get my new pc, one i76600k, asus motherboard pro gamming Z170, amd r9390,16gb ram, ok. My big surprise was as wired router netduma gave me many problems when browsing the Internet, web pages like speed test, the tiendade microsoft fails to load and conexion.Alfinal lost my router with my isp I will perfect . I wonder if netduma have some conflict with the intel drivers of network cards asus, pk I would like to utilzar the netduma router on my new pc. iguaal you have to update netduma? please need help to solve this problem, just something to be configured in net duma, but with the Xbox and the laptop I worked very well. regards
Buds Posted May 7, 2016 Posted May 7, 2016 I am running my new PC on that mobo and no issues with netduma or chipset. I'm afraid its something else or a bad mobo. Good luck, running down these issues can be a real pita!
Netduma Staff Netduma Crossy Posted May 7, 2016 Netduma Staff Posted May 7, 2016 Have you accidentally enabled the GeoFilter for your PC or anything which could be clocking certain websites?
yosu888 Posted May 8, 2016 Author Posted May 8, 2016 Estoy funcionando con mi nuevo equipo en esa placa madre y no había problemas con netduma o conjunto de chips. Me temo que su otra cosa o una mala placa madre. Buena suerte, corriendo por estos temas puede ser un verdadero Pita! if not too much trouble, as you have configured the router netduma for pc? regards
Administrators Netduma Fraser Posted May 9, 2016 Administrators Posted May 9, 2016 As above make sure the Geo-filter is disabled completely. What version are you on?
