IzzyNatural Posted April 19, 2016 Posted April 19, 2016 Sorry if this has been asked before, I couldnt find it anywhere. Is there a cap on the internet speed? I have Fiber Optic - 1 gig and seen a video saying the max speed is 500mb. Will this be cutting my speed in half?? Thanks
UK_Wildcats_Fans Posted April 19, 2016 Posted April 19, 2016 http://wiki.netduma.com/doku.php?id=misc_settings_definitions&s[]=turbo "Turbo" allows speeds up to 500Mbps. "Super Turbo" allows speeds over 500Mbps. I believe that the theoretical max of the R1 is ~900Mbps.
Administrators Netduma Fraser Posted April 20, 2016 Administrators Posted April 20, 2016 Wildcat is correct. Key word is theoretical, I've seen people get up to around 800mbps. You won't be able to make use of all your speed. Considering local congestion may not be too much of an issue for you, then you could just connect console to duma and use it for the Geo-filter.
