need help with my speeds and netduma r1
dbenney
I have a question.  I had a netgear dual band router(dont remember specific model off hand) and when i would run test at speedtest.net both wired and wireless i would constantly get 85Mbs DL and 17 UL...since setting up the netduma i can only get about 65-70 Mbs down and about the same up as before.  I followed the setup and recommended setting and have even played with some settings to try to optimize for my connection.  Am I missing something?  I have seen other people complain of the same thing.  let me know what you guys need to know to try to help me out with this issue.
Thanks
Make sure your running reactive algorithm and have your sliders (congestion control) set at 100/100 when doing tests on a quiet network.It might help your situation get sorted out.
Hey, welcome to the forum. Input speeds into bandwidth and allow to auto setup. Otherwise:
  • 100% anti-flood
  • Reactive algorithm
  • Share excess enabled
  • IPv6 disabled in WAN, LAN & misc
  • Deep packet disabled in misc settings as well
