jsp0511 Posted April 3, 2016 Posted April 3, 2016 Hi all, I'd like to test gameplay with my ps4 capped at various bandwidths to see how the gameplay is. For instance if I want no more than 1mbs going to ps4, how can I set this up?
BulletSponge Posted April 3, 2016 Posted April 3, 2016 Hi, not sure if the CC-Sliders are linear. I think it might also depend on your bandwidth. I throttle when playing BO3. To decide down and up I am doing a speedtest from the Xone.
jsp0511 Posted April 3, 2016 Author Posted April 3, 2016 Hi, not sure if the CC-Sliders are linear. I think it might also depend on your bandwidth. I throttle when playing BO3. To decide down and up I am doing a speedtest from the Xone. I assume if I slide he sliders all the way down then all devices will see the same slower speeds??? I would just like the option to type in the bandwidth number for specific devices. Maybe I should put this in the suggestion forum?
BulletSponge Posted April 4, 2016 Posted April 4, 2016 Hi, as far as i understand things i think you should be able to control bandwith for a certain device using device priorisation (up and down) while share excess is unticked. Nevertheless i would use Congestion Control (CC) at least at 70/70 as recommended. With CC set I would run a speedtest while only one device is online and is at 100% priority or while share excess is ticked. Based on the results i would then decide on the priorisation percentage and untick share excess. You could give it a try and I would be thankful if you would let me know if this is correct so I can improve my knowledge. At my home while playing usually only the Xone is online, so i usually go by setting CC.
jsp0511 Posted April 4, 2016 Author Posted April 4, 2016 Hi, as far as i understand things i think you should be able to control bandwith for a certain device using device priorisation (up and down) while share excess is unticked. Nevertheless i would use Congestion Control (CC) at least at 70/70 as recommended. With CC set I would run a speedtest while only one device is online and is at 100% priority or while share excess is ticked. Based on the results i would then decide on the priorisation percentage and untick share excess. You could give it a try and I would be thankful if you would let me know if this is correct so I can improve my knowledge. At my home while playing usually only the Xone is online, so i usually go by setting CC. I'm not sure I fully understand what you are asking. Yes, you can control bandwidth but not accurately. I had to continuously run speed tests after each time I made an adjustment to get close to my desired speeds. This is not ideal. Also in my case, I don't just have my ps4 going at times. My wife can have her phone watching YouTube and even Netflix running on our smart tv and possibly a laptop on wifi. All simultaneously pulling at the bandwidth. I would like the ability to specify exactly what bandwidth is allotted to each device with the option to have sharers excess on or off for certain devices. I out this in the suggestion area with more detail as to the obstacles and suggestions. http://forum.netduma.com/topic/14374-feature-request-limit-uploaddownload-to-specific-speeds-for-specific-devices/?p=100612&do=findComment&comment=100612
Administrators Netduma Fraser Posted April 4, 2016 Administrators Posted April 4, 2016 You can adjust the % you prioritise the console at which will achieve the same effect. I have posted in your suggestion thread that we'll be implementing more fine tuning in the next upgrade.
jsp0511 Posted April 4, 2016 Author Posted April 4, 2016 You can adjust the % you prioritise the console at which will achieve the same effect. I have posted in your suggestion thread that we'll be implementing more fine tuning in the next upgrade. Yea I guess this thread is a bit redundant now that I look at it. I definitely understand that it can be done with the tools provided. It's just a bit cumbersome, time consuming and a bit askew. I'm looking forward to the update. I love the fact that you (netduma) are as excited about your product as your customers. One of the best purchases for me!
Administrators Netduma Fraser Posted April 5, 2016 Administrators Posted April 5, 2016 Great to hear that!
