Janco Posted April 2, 2016 Posted April 2, 2016 So 343 in their wisdom have removed the region lock which made Halo 5 playable. Now it has gone back to its utterly atrocious original state. My question is does the duma work with H5 now? Successfully?
Administrators Netduma Fraser Posted April 4, 2016 Administrators Posted April 4, 2016 Yes it should work. Make sure you have strict on, PA 0. Due to the way it will work, you'll have to keep searching and getting booted but you should force EU host after a few retries.
