Problem with ip tv device..
gkontos10
The device called max digital xp1000 (cloud ibox ii)
I don't remember that i did any settings to the old router (i think no)
But i don't know for port forwarding
Is there a certain error message you get? Is it just that is does't connect to the internet?
It's telling me connect to the Internet ok..
But its not showing any channel
Is there an internet test that you can run and then post a pic of the results? Or a detail page of the connection? :)
As you cab understand am a dummy on that, so can you please clear it out?
Were to put them and how? :-P
The pic said that DCHP was enabled? Try setting it to disabled and you might be able to manually enter the details - not sure if this will work though  :)
