ugotstretched Posted March 5, 2015 Posted March 5, 2015 Im located on the east coast and for some reason keep connecting to a host form the other side of The usa
Clinton92 Posted March 5, 2015 Posted March 5, 2015 Im located on the east coast and for some reason keep connecting to a host form the other side of The usa Do you have pa on ? If you do thats why you are connecting to the other side of usa.
Clinton92 Posted March 5, 2015 Posted March 5, 2015 Lets say you have your pa set to 50ms. And your geo set to say 1000km, any host or server outside of your geo. With a 50ms or below ping you will be connected to. If you dont want this to happen just set the pa to 0%. But it will make it harder to find games in a low populated area. also make sure strict mode is turned on. Hopefully this helps you out.
Netduma Staff Netduma Crossy Posted March 5, 2015 Netduma Staff Posted March 5, 2015 Im located on the east coast and for some reason keep connecting to a host form the other side of The usa What version are you on? It will say at the bottom of the R1 home page. If you are on .7, it could be because you don't have "Strict Mode" enabled, or as Clinton said, you could be getting connected to it via ping assist. Could you post a screen shot of your GeoFilter while connected to the host?
Guest Netduma_Iain Posted March 5, 2015 Posted March 5, 2015 Cheers guys, you gave better more succinct answers then I could come up!
