ByMgRs Posted March 3, 2016 Posted March 3, 2016 Ok so I just had Sky Q installed and I have setup my R1 with my Sky Q hub (Yes I have to use it due to MER encryption forced on customers) but if I try and use my phone or laptop which is connected to the sky hub wifi then I cannot access the R1 interface by using 'r1' or its ip address on the immediate network. Is there any way of doing this? (will allow access from wan work? It hasnt so far?)
RADDY1993 Posted March 3, 2016 Posted March 3, 2016 Ok so I just had Sky Q installed and I have setup my R1 with my Sky Q hub (Yes I have to use it due to MER encryption forced on customers) but if I try and use my phone or laptop which is connected to the sky hub wifi then I cannot access the R1 interface by using 'r1' or its ip address on the immediate network. Is there any way of doing this? (will allow access from wan work? It hasnt so far?) If your phone or laptop is connected to the hub then it wont, connect to the Duma wifi then it should.
Administrators Netduma Fraser Posted March 4, 2016 Administrators Posted March 4, 2016 You can try access from WAN - to get to the router interface you would then put your public IP address in your web browser. Definitely the easier (and safer) suggestion is above
ByMgRs Posted March 5, 2016 Author Posted March 5, 2016 You can try access from WAN - to get to the router interface you would then put your public IP address in your web browser. Definitely the easier (and safer) suggestion is above Ah after a reset it worked
