hilly_r1 Posted March 1, 2016 Posted March 1, 2016 I have latest update on my Netduma and my Virgin media super hub 2 is set to modem mode, everthing wired up, when I run speed test on my wired laptop it's showing my downloads and uploads are lower than they where when I ran the test on my ISP router, just need some advice on my Netduma settings thanx in advance
ImSallad Posted March 1, 2016 Posted March 1, 2016 what speeds do you have? have you set your bandwidth in congestion control? are both sliders on 100% in congestion control?
hilly_r1 Posted March 1, 2016 Author Posted March 1, 2016 I'm on the top Virgin broadband I should be getting at least 150 download and about 12 up and yes to the above , it should look like your test
hilly_r1 Posted March 1, 2016 Author Posted March 1, 2016 I'm only getting 9 download and about 8 up, when the Netduma connected
ImSallad Posted March 1, 2016 Posted March 1, 2016 go to settings then miscellaneous and tick turbo mode
ImSallad Posted March 1, 2016 Posted March 1, 2016 Have you tried to turn the NetDuma off for 5 minutes? That might help clear up any issues!
Macca65 Posted March 1, 2016 Posted March 1, 2016 i have the same set up. Virgin 150 ul 12dl. SH in modem mode. Ensure you have the device priority set to the maximum for your laptop and try a speed test again
hilly_r1 Posted March 1, 2016 Author Posted March 1, 2016 Give up tried turning it off still the same , the problem is the Netduma not my ISP
hilly_r1 Posted March 1, 2016 Author Posted March 1, 2016 Yep done that set upload and download all to pc, even plugged it straight into the back of the netduma instead of it being upstairs which is also wired, fed up of this to be honest I switch my vm hub back as a router and I get full speeds again, must be a setting somewhere
hilly_r1 Posted March 2, 2016 Author Posted March 2, 2016 Sorted , just turned both routers off over night , re ran speed test this morning , everthing as it should be ,
Administrators Netduma Fraser Posted March 2, 2016 Administrators Posted March 2, 2016 Great, as this has been resolved I'll now close this thread. Please feel free to open another if you have any other questions/issues.
