DivineDG Posted February 20, 2016 Posted February 20, 2016 Hi Pretty much as the topic says - im wired with an ethernet cable but when i look on device manager it says that my PS4 is wireless, any ideas?
willphule Posted February 21, 2016 Posted February 21, 2016 This is a just a thought, and you may have already checked but if not... Even if you have an ethernet cable plugged in you have to go to your PS4 network settings to set it up as wired as doesn't automatically switch - if you had setup the wireless at some point prior it will default to that unless you go in and change it.
DivineDG Posted February 21, 2016 Author Posted February 21, 2016 This is a just a thought, and you may have already checked but if not... Even if you have an ethernet cable plugged in you have to go to your PS4 network settings to set it up as wired as doesn't automatically switch - if you had setup the wireless at some point prior it will default to that unless you go in and change it. Thanks mate that has sorted it!
Administrators Netduma Fraser Posted February 22, 2016 Administrators Posted February 22, 2016 Great, as this has been resolved I'll now close this thread. Please feel free to open another if you have any other questions/issues.
