Low Resolution Map and hiper traffic
Hi I would like to know is Low Resolution Map, I would also like to know if it's good hipper trafic activate the device xbox one
Low resolution map is for browsers such as Safari which have a hard time showing the detail on the Geo-filter map properly so it reduces the detail. Not needed if you're using Chrome/Firefox.
Yes I would recommend enabling your xbox under hyper traffic.
Damn good question as I was wondering what the low resolution map was all about too,thanks Fraser
