F3arless27 Posted February 9, 2016 Posted February 9, 2016 keep getting knocked out of my party and can't connect on xbox one after i ban a temp server
Asentrix Posted February 9, 2016 Posted February 9, 2016 keep getting knocked out of my party and can't connect on xbox one after i ban a temp server Most likely because your party are able to connect to the dedi but you can't You would need to be host for it to work correctly ( I assume) or solo
Administrators Netduma Fraser Posted February 9, 2016 Administrators Posted February 9, 2016 Most likely because your party are able to connect to the dedi but you can't You would need to be host for it to work correctly ( I assume) or solo Other than above. Have you added everyone to your allow list? Is may be misclassified as a dedicated server that needs to be whitelisted but this is unlikely.
F3arless27 Posted February 9, 2016 Author Posted February 9, 2016 Other than above. Have you added everyone to your allow list? Is may be misclassified as a dedicated server that needs to be whitelisted but this is unlikely.
F3arless27 Posted February 9, 2016 Author Posted February 9, 2016 It appeared to be a dedicated server, and I'm in Texas the host was north east playing w people in Wisconsin so shouldn't of knocked me out of the party
F3arless27 Posted February 9, 2016 Author Posted February 9, 2016 I haven't white listed anyone yet not exactly sure just click on their host circle and give a high rating right?
Administrators Netduma Fraser Posted February 10, 2016 Administrators Posted February 10, 2016 It appeared to be a dedicated server, and I'm in Texas the host was north east playing w people in Wisconsin so shouldn't of knocked me out of the party It could be incorrectly located. I haven't white listed anyone yet not exactly sure just click on their host circle and give a high rating right? To play with friends follow this guide - http://wiki.netduma.com/doku.php?id=adding_friends_to_your_allow_list
fuzzy clam Posted February 10, 2016 Posted February 10, 2016 If your gonna use the temp ban feature just make sure you're the party leader.As stated above and thru my testing if you ban a server and are in a party but not the party leader you will get booted from the party,as you are the only one who the server is blocked for and not the party leader.
