Zero_Actual Posted February 5, 2016 Posted February 5, 2016 Just noticed that the servers do not flash up on the geofilter when I initially load the game. Tried it twice to no avail. Any reason why this would be occurring?
Scrizzy Posted February 5, 2016 Posted February 5, 2016 You should have the dormant hosts option ticked in the geo filter at startup. You should also disable the geofilter at startup if you want to see all servers highlighted, then you can enable your filters thereafter
PharmDawgg Posted February 5, 2016 Posted February 5, 2016 Fraser put a huge cloud update so that could have something to do with it. Go into settings>misc and uncheck enable auto cloud and bleeding edge then click apply. Then recheck both and click apply again. This what we call flushing the cloud. It may take a while for it to update. See if this helps.
Zero_Actual Posted February 5, 2016 Author Posted February 5, 2016 All filters were disabled, ticked show dormant hosts. Will try updating the cloud. Another issue is I have ping assist set to 31ms, strict mode ticked, geo as small as possible but I continue to get put into games with 50-75ms.
Scrizzy Posted February 5, 2016 Posted February 5, 2016 50-75 as shown on the duma? or youre seeing that on the in game ping display? is the host outside of the geo filter range circle?
Zero_Actual Posted February 5, 2016 Author Posted February 5, 2016 On the Duma. And yes the host is outside the geo.
Netduma Staff Netduma Crossy Posted February 5, 2016 Netduma Staff Posted February 5, 2016 On the Duma. And yes the host is outside the geo. What version are you on?
