3zo000oz Posted January 24, 2016 Posted January 24, 2016 Hi everyone I'm new to netduma i just got my router few days ago I have great experience with it so far but i have this problem and I couldn't find a solution I use hotspot shiled on my ipad before using netduma and it was working but after i used netduma i get connected to a vpn server but I can't open any page I tired to use my old router and it worked fine And I don't want to use the in router vpn setting i just want to use the app in my ipad turn it on and off anytime Is there a solution for this problem My settings in the router for destiny i took them from the wiki Thanks
Netduma Staff Netduma Crossy Posted January 24, 2016 Netduma Staff Posted January 24, 2016 Hey, welcome to the forum Have you added your iPad to the GeoFilter by any chance which could be blocking the VPN server?
3zo000oz Posted January 24, 2016 Author Posted January 24, 2016 No i only added my ps4 And tried my iphone same problem
Netduma Staff Netduma Crossy Posted January 24, 2016 Netduma Staff Posted January 24, 2016 No i only added my ps4 And tried my iphone same problem If you change to the reactive algorithm in congestion control does it work?
3zo000oz Posted January 24, 2016 Author Posted January 24, 2016 I'm on reactive And tried the other one same issue
Netduma Staff Netduma Crossy Posted January 24, 2016 Netduma Staff Posted January 24, 2016 I'm on reactive And tried the other one same issue Could you try uninstalling their app then re-installing it?
3zo000oz Posted January 24, 2016 Author Posted January 24, 2016 Could you try uninstalling their app then re-installing it? I did didn't work And i tried to reinstall the profile as well
Netduma Staff Netduma Crossy Posted January 24, 2016 Netduma Staff Posted January 24, 2016 I did didn't work And i tried to reinstall the profile as well Do you have an internet connection through the device when you're not using the VPN?
3zo000oz Posted January 24, 2016 Author Posted January 24, 2016 Do you have an internet connection through the device when you're not using the VPN? Yea everything works fine But when i connect to the vpn server I can't use the internet
Netduma Staff Netduma Crossy Posted January 24, 2016 Netduma Staff Posted January 24, 2016 Yea everything works fine But when i connect to the vpn server I can't use the internet If you change the DNS servers on the Netduma (in Settings >> LAN) to 8.8.8.8 and 8.8.4.4 does it work?
3zo000oz Posted January 25, 2016 Author Posted January 25, 2016 If you change the DNS servers on the Netduma (in Settings >> LAN) to 8.8.8.8 and 8.8.4.4 does it work? no luck so far
Netduma Staff Netduma Crossy Posted January 25, 2016 Netduma Staff Posted January 25, 2016 no luck so far Ok, hopefully Fraser can help you today when he's on
3zo000oz Posted January 25, 2016 Author Posted January 25, 2016 Ok, hopefully Fraser can help you today when he's on thanks for the help BTW i will wait for his respons
Administrators Netduma Fraser Posted January 25, 2016 Administrators Posted January 25, 2016 Does Hotspot give you any kind of error when connecting to it?
3zo000oz Posted January 25, 2016 Author Posted January 25, 2016 Does Hotspot give you any kind of error when connecting to it?No it is like normally connected but when i try open any web page is like there no internet I tried today at work and it works fine But at home i get this problem maybe somthing in the settings in netduma but im not sure
Administrators Netduma Fraser Posted January 27, 2016 Administrators Posted January 27, 2016 No it is like normally connected but when i try open any web page is like there no internet I tried today at work and it works fine But at home i get this problem maybe somthing in the settings in netduma but im not sure Can you try disabling wifi workaround in settings > workaround - just a theory. But here are suggestions from their website: Open Hotspot Shield, and turn Protection OFF and ON. Wait for Hotspot Shield to connect, it might take a few moments. ------------- Go to your device's Settings. Turn Airplane Mode ON and OFF. Open Hotspot Shield, and turn Protection OFF and ON.
3zo000oz Posted January 27, 2016 Author Posted January 27, 2016 Can you try disabling wifi workaround in settings > workaround - just a theory. But here are suggestions from their website: Open Hotspot Shield, and turn Protection OFF and ON. Wait for Hotspot Shield to connect, it might take a few moments. ------------- Go to your device's Settings. Turn Airplane Mode ON and OFF. Open Hotspot Shield, and turn Protection OFF and ON. I tried it just now its not working either
3zo000oz Posted January 29, 2016 Author Posted January 29, 2016 Please close the thread i solved the problem Turbo mode what cause the issue I don't know why i turned it off and it worked fine Thanks
Administrators Netduma Fraser Posted January 29, 2016 Administrators Posted January 29, 2016 Please close the thread i solved the problem Turbo mode what cause the issue I don't know why i turned it off and it worked fine Thanks Interesting okay, thanks for letting us know what solved the issue. Will keep that in mind for the future!
