gurthyjohnson Posted January 17, 2016 Posted January 17, 2016 I recently got my netduma router, i went through the tutorial on the website. When i am in the Host Filtering tab i will change my distance and ping, if i go to another tab like congestion control and then go back to the host filtering tab its back to normal. When i change my upload/download cap or set my bandwith or distribution on the congestion control tab and then leave to another tab, everything is reset like i didnt make any changes when i come back to congestion control.
Netduma Staff Netduma Crossy Posted January 17, 2016 Netduma Staff Posted January 17, 2016 Hey, welcome to the forum Can you make sure you are using Google Chrome as your browser.
moffek1 Posted January 18, 2016 Posted January 18, 2016 This one tip saved me hours of pain. I was struggling to upgrade and change settings and after reading this it is so much easier. Thanks
TEH BUTCHER Posted January 18, 2016 Posted January 18, 2016 Also enable cookies on the misc settings.
